6 years agoNot applicable
Need help - Column difference in a matrix
Good afternoon all! I'm in dire need of some help. I have the following matrix making use of 3 fields: Description Period Cost My issue is the following, i want to add a column...
- 6 years ago
Hi Anonymous
Create measures
Measure 2 = VAR m1 = MINX ( ALLSELECTED ( 'Table 2' ), [period] ) VAR m2 = MAXX ( ALLSELECTED ( 'Table 2' ), [period] ) RETURN CALCULATE ( SUM ( 'Table 2'[cost] ), FILTER ( 'Table 2', 'Table 2'[period] = m2 ) ) - CALCULATE ( SUM ( 'Table 2'[cost] ), FILTER ( 'Table 2', 'Table 2'[period] = m1 ) ) Measure = IF(ISINSCOPE('Table 2'[period]),SUM('Table 2'[cost]),[Measure 2])Best Regards
Maggie
6 years agoMake sure period are in a separate table for better working
Measure =
var _min = minx(Period,Period[Name])
var _max = maxx(Period,Period[Name])
return
calculate(sum(table[cost]),filter(all(Period),Period[Name]=_min)) -calculate(sum(table[cost]),filter(all(Period),Period[Name]=_max))
if you need more help make me @
Appreciate your Kudos.
thanks amitchandak , i tried this and didnt give any errors, but it doesnt want to do the calculation. It just returns a 0.
- amitchandak6 years ago
Can you share sample data and sample output.
