3 years agoNot applicable
Missing groupby columns while using pandas dataframe
Hi Experts, I am trying the PoC of a project via loading data from excel file(just taking excel as an example.) and transform in python dataframe, then load to Power bi. . It runs well in PyDev....
Thanks lbendlin. Yes I noticed it. I think it is due to how Power BI interpretes the dataframe which is pivtol. I did export the groupbyed dataframe to csv. the format is correct. For the above scenario, your are right, no need of python. but the project might have more complex logics, for example , the order of different queries, and the results criterias matching. I had a post before, but didn't seem to be possible just in PQ or PBI domians.
The current approach is to use Python to proscess the data and load to PBI for visualization.
Any other better solution?
Thanks!
lbendlin
3 years agoSuper User
Power Query and VBA do not mix well. They have very different philosophies. I assume you have seen this advice
the BackgroundQuery=True must be set. otherwise, if it set to False the afterfresh event will not be triggered
