Help - Power Query Drill Through
Can anyone give me some help?
My Power BI desktop verion is July 2025. I am trying to set up an page as drill through page, however, I can't find the drill through option under Page information. Below is what I saw:
Can someone instruct me how to set up an drill-through page by an invoice No. (not a measure), simply just a text field? Appreciated!
Hi annatan ,
Please Navigate to File -> Options & Settings -> Options then select the below highlighted Option then save the report and close and reopen the report and check this option.
Please mark it as a solution if it solves your issue.
You need to add a drillthrough field to a page
- Aburar_123
Solution Supplier
Hi annatan ,
- danextian
