annatan
Helper II
1 year agoHelp - Power Query Drill Through
Hi, Can anyone give me some help? My Power BI desktop verion is July 2025. I am trying to set up an page as drill through page, however, I can't find the drill through option under Page inf...
- 1 year ago
Hi annatan ,
Please Navigate to File -> Options & Settings -> Options then select the below highlighted Option then save the report and close and reopen the report and check this option.
Please mark it as a solution if it solves your issue.
- 1 year ago
You need to add a drillthrough field to a page
danextian
1 year agoYou need to add a drillthrough field to a page
