annatan's avatar
annatan
1 year ago
Help - Power Query Drill Through
Hi,    Can anyone give me some help?    My Power BI desktop verion is July 2025. I am trying to set up an page as drill through page, however, I can't find the drill through option under Page inf...
  • Aburar_123's avatar
    1 year ago
    Hi annatan ,
    Please Navigate to File -> Options & Settings -> Options then select the below highlighted Option then save the report and close and reopen the report and check this option.
    Please mark it as a solution if it solves your issue.
  • danextian's avatar
    1 year ago
    You need to add a drillthrough field to a page
