dirkkoch's avatar
dirkkoch
3 years ago
Dynamically subtract two values in same column between two dates
I have two columns (one with values, one with dates, see Screenshot marked red). I want to create a calculated column which subtracts each value with the one from the former date (see desired result written in the column on the right hand side).
I know I have to use the earlier-function but I did not get what I wanted so far.
I would be thankful for support!
  • Hi,
    I did as below :
    1- Add the Index column to the table in Power Query.
    2- Then use below code for create the new column :
    DiffVal Col =
    Var __CurrIndex = Sheet57[Index]
    Var __CurVal = (Sheet57[Value])
    Var __BeforeVal = CALCULATE(sum(Sheet57[Value]), filter(sheet57, Sheet57[Index] = __CurrIndex - 1 ))
    return __CurVal - __BeforeVal
    Appreciate your Kudos and please mark it as solution if it helps you
  • MahyarTF's avatar
    MahyarTF
    Icon for Memorable Member rankMemorable Member
    I did as below :
    DiffVal Col =
    • daXtreme's avatar
      daXtreme
      Icon for Solution Sage rankSolution Sage
      MahyarTF
      THe problem with your solution is that it makes the model unnecessarily bloated (as the index column is not really needed). Second, calculated columns are not compressed the way they are when created in Power Query - this results in even more bloat. In big models this may be unacceptable. Therefore, please use Power Query to do such calculations. Unless, of course, you don't care about how big the model is and how fast DAX could be. But I think you should since you pay money for storage. You also want to have fast DAX and columns optimized for access and calculations.
      • MahyarTF's avatar
        MahyarTF
        Hi daXtreme ,
        Thanks for your useful advice.
        Just learning and trying to improve my knowledge.
        This is the solution it was at top of my head but absolutely there are better solutions.
    • dirkkoch's avatar
      dirkkoch
      MahyarTF
      Thanks! Yes, that would work if there is a value in each row of the column. Unfortunately there might be some blanks, meaning that if there is no value, it should substract the actual with the last availabe value in the column
      • MahyarTF's avatar
        MahyarTF
        Hi dirkkoch
        Please try the below code in the new column I described earlier :
        DiffVal Col =
        Var __PreviousIndex = CALCULATE(max(Sheet57[Index]), all(Sheet57), Sheet57[Index] < __CurrIndex, not(ISBLANK(Sheet57[Value])))
        Var __BeforePreviousIndex = CALCULATE(max(Sheet57[Index]), all(Sheet57), Sheet57[Index] < __PreviousIndex, not(ISBLANK(Sheet57[Value])))
        Var __PreviousVal = CALCULATE(sum(Sheet57[Value]), filter(sheet57, Sheet57[Index] = __PreviousIndex))
        Var __BeforePreviousVal = CALCULATE(sum(Sheet57[Value]), filter(sheet57, Sheet57[Index] = __BeforePreviousIndex))
        Var __NextVal = CALCULATE(sum(Sheet57[Value]), filter(sheet57, Sheet57[Index] = __CurrIndex+1))
        Var __CurVal = if(ISBLANK(Sheet57[Value]), __NextVal,Sheet57[Value])
        return if(ISBLANK(Sheet57[Value]), __PreviousVal - __BeforePreviousVal, __CurVal - __PreviousVal)
        Appreciate your Kudos and please mark it as a solution if it helps you
  • daXtreme's avatar
    daXtreme
    Use Power Query for this because this is where such calculations belong. By the way, the EARLIER function in DAX has been discouraged and you should learn to use variables instead.
    Source: https://dax.guide/earlier
