dirkkoch
Helper III
3 years agoDynamically subtract two values in same column between two dates
Hi, I have two columns (one with values, one with dates, see Screenshot marked red). I want to create a calculated column which subtracts each value with the one from the former date (see desired...
- 3 years ago
I did as below :
1- Add the Index column to the table in Power Query.
2- Then use below code for create the new column :
DiffVal Col =Var __CurrIndex = Sheet57[Index]Var __CurVal = (Sheet57[Value])Var __BeforeVal = CALCULATE(sum(Sheet57[Value]), filter(sheet57, Sheet57[Index] = __CurrIndex - 1 ))return __CurVal - __BeforeValAppreciate your Kudos and please mark it as solution if it helps you
