gonnelli
7 years agoFrequent Visitor
Difference between 2 rows using first row fixed
Hello! I need to calculate the difference between two rows in a matrix table in Power BI, but I need to keep the first row as reference, like this: EDIT: The first row (Model "A") can be chan...
- 7 years ago
Hi gonnelli,
Does that make sense? If so, kindly mark my answer as a solution to close the case.
Frank
gonnelli
Hello v-frfei-msft
In my case, I can't use lookupvalues because the first "model" can be changed by filters.
I need to calculate always the difference between the first row with another rows.
v-frfei-msft
7 years agoCommunity Support
Hi gonnelli,
I made an update of the measure.
diffm = MAX(Table1[price])-CALCULATE(SUM(Table1[price]),FILTER(ALLSELECTED(Table1),Table1[model]=MINX(ALLSELECTED(Table1),Table1[model])))
For more details, please check the pbix as attached.
Frank
- v-frfei-msft7 years agoCommunity Support
Hi gonnelli,
Frank
