Difference between 2 rows using first row fixed
- 7 years ago
Hi gonnelli,
Does that make sense? If so, kindly mark my answer as a solution to close the case.
Frank
Have you tried using the LOOKUPVALUE function? You can use this to return the value for Model A in whatever column you need to reference.
In your example below, the formula would look something like (I'm using "Table1" as the table where your values are stored in this example):
diff = CALCULATE(AVERAGE(Table1[price])-LOOKUPVALUE(Table1[price],Table1[model],"A"))
- gonnelli7 years agoFrequent Visitor
Hello v-frfei-msft
In my case, I can't use lookupvalues because the first "model" can be changed by filters.
I need to calculate always the difference between the first row with another rows.
- v-frfei-msft7 years agoCommunity Support
Hi gonnelli,
I made an update of the measure.
diffm = MAX(Table1[price])-CALCULATE(SUM(Table1[price]),FILTER(ALLSELECTED(Table1),Table1[model]=MINX(ALLSELECTED(Table1),Table1[model])))
For more details, please check the pbix as attached.
Frank
Hi gonnelli,
Frank
