Calculating difference between dates
- 6 years ago
Hi Anonymous ,
We can use the following measure to meet your requirement.
Days Until 1 = VAR thisdate = MAX ( 'Table'[Date] ) VAR thisid = MAX ( 'Table'[ID] ) VAR thisHCvalue = MIN ( 'Table'[HC] ) VAR next1date = CALCULATE ( MAX ( 'Table'[Date] ), FILTER(ALLSELECTED ( 'Table' ), 'Table'[ID]=thisid && 'Table'[HC]=0 )) RETURN IF ( OR ( ISBLANK ( next1date ), thisHCvalue <> 0 ), 0, DATEDIFF ( thisdate, next1date, DAY ) )The result like this,
If it doesn’t meet your requirement, could you please show the exact expected result based on the table that you have shared?
It will be helpful if you can show us the exact expected result.
BTW, pbix as attached.
Best regards,
Community Support Team _ zhenbw
Hi Anonymous ,
How about the result after you follow the suggestions mentioned in my original post?
Could you please provide more details or expected result about it If it doesn't meet your requirement?
Best regards,
