6 years agoNot applicable
Calculating difference between dates
Hello, I need to calculate the difference between dates if certain conditions are met, sample data: ID Category HC Date 1 A 0 01/01/2019 2 A 1 01/01/2019 3 B 1 01/01/2019 ...
- 6 years ago
Hi Anonymous ,
We can use the following measure to meet your requirement.
Days Until 1 = VAR thisdate = MAX ( 'Table'[Date] ) VAR thisid = MAX ( 'Table'[ID] ) VAR thisHCvalue = MIN ( 'Table'[HC] ) VAR next1date = CALCULATE ( MAX ( 'Table'[Date] ), FILTER(ALLSELECTED ( 'Table' ), 'Table'[ID]=thisid && 'Table'[HC]=0 )) RETURN IF ( OR ( ISBLANK ( next1date ), thisHCvalue <> 0 ), 0, DATEDIFF ( thisdate, next1date, DAY ) )The result like this,
If it doesn’t meet your requirement, could you please show the exact expected result based on the table that you have shared?
It will be helpful if you can show us the exact expected result.
BTW, pbix as attached.
Best regards,
Community Support Team _ zhenbw
mahoneypat
6 years agoPlease try this measure expression in a table with Date and ID columns. It will get the shown result.
Days Until 1 =
VAR thisdate =
SELECTEDVALUE ( HC[Date] )
VAR thisid =
SELECTEDVALUE ( HC[ID] )
VAR thisHCvalue =
MIN ( HC[HC] )
VAR next1date =
MAX ( HC[Date] ),
ALL ( HC ),
VALUES ( HC[ID] ),
HC[Date] > thisdate,
HC[HC] = 1
IF (
0,
