Learn moreDid you hear? There's a new SQL AI Developer certification (DP-800). Start preparing now and be one of the first to get certified. Register now
Tengo un script de python con los pandas de módulo. Este script funciona bien en Anaconda Spyder. Cuando uso esto en Power BI, obtengo este error:
C:\Users\xxxx\Anaconda3\lib\site-packages\numpy\__init__.py:143: UserWarning: mkl-service package failed to import, therefore Intel(R) MKL initialization ensuring its correct out-of-the box operation under condition when Gnu OpenMP had already been loaded by Python process is not assured. Please install mkl-service package, see http://github.com/IntelPython/mkl-service
from . import _distributor_init
Traceback (most recent call last):
File "PythonScriptWrapper.PY", line 2, in <module>
import os, pandas, matplotlib
File "C:\Users\xxxx\Anaconda3\lib\site-packages\pandas\__init__.py", line 16, in <module>
raise ImportError(
ImportError: Unable to import required dependencies:
numpy:
IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
Importing the numpy C-extensions failed. This error can happen for
many reasons, often due to issues with your setup or how NumPy was
installed.
We have compiled some common reasons and troubleshooting tips at:
https://numpy.org/devdocs/user/troubleshooting-importerror.html
Please note and check the following:
* The Python version is: Python3.8 from "C:\Users\xxxx\Anaconda3\python.exe"
* The NumPy version is: "1.20.1"
and make sure that they are the versions you expect.
Please carefully study the documentation linked above for further help.
La versión de Python y Numpy son:
- 1.20.1 1Numpy
- 3.8.8 Pitón
¿Qué puedo hacer aquí???
Thx
Torsten
@torsten_FO , Por favor refiérase a esta descripción del video, donde he desusado estos problemas
