Power BI Desktop 32bit not working with Access 32bit
- Anonymous9 years ago
Hi Vojta,
The above error message indicates the Access Database Engine in not installed on your machine, please download 32-bit Access Database Engine 2010 Redistributable and install it, then check if you are able to connect to Access database from Power BI Desktop.
If the issue still persist, please help to share your Access database, I will test it in my Desktop.
Reference: https://powerbi.microsoft.com/en-us/documentation/powerbi-desktop-access-database-errors/
Lydia Zhang
I have a problem getting data into Power Bi Desktop from Access, could you please advise?
- Win 10
- Power BI Desktop 32bit (2,40,4554,421 32 bit)
- Access Pro Plus O365 (Version 16,0,7167,2060)
Unable to Connect
Details: "Microsoft Access: The 'Microsoft.ACE.OLEDB.12.0' provider is not registered on the local machine. The 32-bit version of the Access Database Engine 2010 Access Database Engine OLEDB provider is required to connect to read this type of file. To download the client software, visit the following site: https://go.microsoft.com/fwlink/?LinkID=285987."
