OneLake connection in Power BI does not work
Hi all,
In PowerBI, I am trying to connect my new lakehouse as data source. Unfortunately, I cannot make it work.
The steps I do: first, I click OneLake data hub, then Lakehouses.
Then I select my lakehouse, in this case Mar_Com_Gold:
en then click Connect.
Then it seems like he is connecting, but in the end my Data pane is empty and the OneLake button (and others) are greyed-out.
Can someone help me out?
Thank you in advance.
yes this was fixed through this forum item:
- notnexpertNew Member
I had the same issue. This is what worked for me.
1. Adding default dataset objects in model view to connect via lakehouse.
2. Adding tables to default semantic model to connect via semantic model.
- AnonymousNot applicable
Hi Fave24
Check if your dataset is too large for slow loading, and you can try to clear the data permissions at data source settings and then reconnect to the data source.
Best Regards!
Yolo Zhu
- Fave24Frequent Visitor
Hi Anonymous
Thanks for replying.
Unfortunately, clearing the data permissions and setting to the large semantic model did not work 😞
Any other ideas?
This option (see screenshot below) works right away, but what is exactly the difference between connecting to the Lakehouse or connecting to the semantic model?
Hi Fave24
Please make sure the version of your Power BI Desktop is the latest, then try to uninstall Power BI Desktop and reinstall it and connect the lakehouse again.
Best Regards!
Yolo Zhu
Did you get this fixed? I am having the same issue.
