Don't miss out! 2025 Microsoft Fabric Community Conference, March 31 - April 2, Las Vegas, Nevada. Use code MSCUST for a $150 discount. Prices go up February 11th. Register now.
Fave24
OneLake connection in Power BI does not work
Hi all,
In PowerBI, I am trying to connect my new lakehouse as data source. Unfortunately, I cannot make it work.
The steps I do: first, I click OneLake data hub, then Lakehouses.
Then I select my lakehouse, in this case Mar_Com_Gold:
en then click Connect.
Then it seems like he is connecting, but in the end my Data pane is empty and the OneLake button (and others) are greyed-out.
Can someone help me out?
Thank you in advance.
Fave24
7 REPLIES 7
BTex06
Did you get this fixed?  I am having the same issue.
Fave24
notnexpert
I had the same issue. This is what worked for me.
1. Adding default dataset objects in model view to connect via lakehouse.
2. Adding tables to default semantic model to connect via semantic model.
v-xinruzhu-msft
Hi @Fave24
Check if your dataset is too large for slow loading, and you can try to clear the data permissions at data source settings and then reconnect to the data source.
Best Regards!
Yolo Zhu
Hi @v-xinruzhu-msft
Thanks for replying.
Unfortunately, clearing the data permissions and setting to the large semantic model did not work 😞
Any other ideas?
This option (see screenshot below) works right away, but what is exactly the difference between connecting to the Lakehouse or connecting to the semantic model?
Hi @Fave24
Please make sure the version of your Power BI Desktop is the latest, then try to uninstall Power BI Desktop and reinstall it and connect the lakehouse again.
Best Regards!
Yolo Zhu
Hi @v-xinruzhu-msft
I uninstalled Power BI desktop, reinstalled it and tried to connect the lakehouse again. Unfortunately, again no positive results. We also tried to connect the lakehouse on another computer in Power BI, again it did not connect.
We also made a new lakehouse, but again the same problems...
But I can connect to a dataset in the lakehouse by connecting to a new set semantic model in the same lakehouse. See screenshot in previous reply. As long as I cannot fix the direct connection to the lakehouse, I think I will use this connection. Is there a good alternative? Or are there reasons, not to connect to the semantic model?
Las Vegas 2025
March 31 - April 2, 2025, in Las Vegas, Nevada. Use code MSCUST for a $150 discount! Prices go up Feb. 11th.
Jan25PBI_Carousel
Power BI Monthly Update - January 2025
Check out the January 2025 Power BI update to learn about new features in Reporting, Modeling, and Data Connectivity.
Jan NL Carousel
Fabric Community Update - January 2025
