How to create a shift rotation schedule in Power Bi?
- 4 years ago
I think the simplest method would be to set up your pattern and use Table.Repeat to copy it as many times as you want.
I filtered to the first 8 rows and removed the Week column before repeating and then added back the Week column by defining a new index column:
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMlTSUQrOyEwrUTC0MkKw4SwjpVidaCUjrKqQ1YNUGRNllglRZpli0Y+qHqTKDKstyOpBqsyJMsuCKLMsifKjoQFRnjQkLvQNiQj+WAA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [Week = _t, Night = _t, Evening = _t, Day = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"Week", Int64.Type}}), #"Filtered Rows" = Table.SelectRows(#"Changed Type", each [Week] <= 8), #"Repeated Table" = Table.Repeat(Table.RemoveColumns(#"Filtered Rows",{"Week"}), 7), #"Added Index" = Table.AddIndexColumn(#"Repeated Table", "Week", 1, 1, Int64.Type) in #"Added Index"Repeating 7 times (as above) returns 56 rows. You can trim off extra rows or repeat more time as you see fit.
- 4 years ago
Create a new blank query (or duplicate any existing query) and open the advanced editor and replace all the text with the M code I provided. This will recreate exactly what I did and you can walk through the applied steps.
Instead of connecting to a source, I use the Enter Data tool. The long green text is that entered data in a compressed format.
To apply to your data, you're essentially trying to recreate the last three steps (Filtered Rows, Repeated Table, and Added Index).
#"Added Index"
I've been trying to figure out how to manage this code related to my data. Is there a possibility you could simplify this example a litte more? For an example, the long green text - is that a source? And where do i put this code - Power Bi or the Query?
// Noob 😄
- AlexisOlson4 years ago
