Open Side Menu
Skip to contentMicrosoft Fabric Community
Forums
Inspiration
Ideas
Communities
Blogs
Learning
Support
RegisterSign In
  1. Microsoft Fabric Community
  2. Power BI forums
  3. Issues
Nishantjain's avatar
Nishantjain
Icon for Continued Contributor rankContinued Contributor
7 years ago
Status:
Done
Power BI Premium Capacity Metrics not refreshing
Hi,    My Power BI Premium Capacity Metrics app has not refreshed since 07th March. The error message is   There weren't enough elements in the enumeration to complete the operation. Table: DQLCM...
Reports
v-qiuyu-msft's avatar
v-qiuyu-msft
7 years ago
Hi Nishantjain,
This is a known issue. You can keep an eye on the status of this issue in Support site:
Qiuyun Yu
Completed Ideas
  • Set as landing page feature missing in Apr 2026 update (Build 2.153.1206.0) both in Desktop and Serv
  • Input Slicer Bug: Cursor jumps to position 0 and values cannot be cleared in Service
  • Input Slicer Causing Browser Tab Freeze in Public Links (Started April 24, 2026)
  • Small multiples not fitting to scale
  • Previously working Mac calender visual now gives me a error every time I touch it!
  • Text Slicer does not reset via Bookmarks or Clear All in Power BI Service (Service-only behavior)
  • Text Input Slicer is not reset by bookmarks in Power BI Service while working correctly in Power BI
  • Azure maps not displaying mapped data points in publish to web when location used
  • Azure Maps reference layer transparency behaves differently after publishing to Power BI Service
  • Desktop Application Bug?? - PBI desktop application left navigation icons always solid black
  • © 2026 Microsoft
  • Privacy & cookies
  • Terms of use
  • Trademarks
Your Privacy Choices Consumer Health Privacy
Share this pageShare on LinkedInShare on FacebookShare on XShare on RedditShare on BlueskySubscribe via RSSShare via email
