Power BI Desktop February 2023 DPI Scaling Problem
We've just pushed Feb 2023 update 2.114.803.0 with some DPI scaling fixes. Please download/install the latest and let us know...
If you still experience DPI scaling issues after update.... Try to change your Main/default monitor in the Settings > Display, Select a screen and check [x] Make this my main screen
And yes, please reply to the thread with additional info re configuration when you see the DPI scaling issues: Settings > Display config <screenshot of screen layout>
For example my config is:
1. Left screen - Laptop: 1920x1080, 100% scaling (Main/Default)
2. Right screen - Monitor: 3840x2160, 150% scaling
Are you using the Remote desktop?
Also let us know your repro steps - something like this:
1. Open PowerBIDesktop on Screen 1 (Left).
2. Go to View > Custom themes and open the Custom themes dialog on Screen 1 (Left).
3. The dialog looks clipped <screenshot>
4. Close the dialog and reopen it...
5. Dialog still looks clipped...
Thanks!
