Open Side Menu
Skip to contentMicrosoft Fabric Community
Forums
Inspiration
Ideas
Communities
Blogs
Learning
Support
RegisterSign In
  1. Microsoft Fabric Community
  2. Power BI forums
  3. Issues
Anonymous's avatar
3 years ago
Status:
Done
Power BI Desktop February 2023 DPI Scaling Problem
Since updating to this month's new Power BI Desktop release, the UI appears to be using my secondary display's DPI scaling upon launching a pbix file. The UI is blurry and zoomed in until I resize th...
Data Modeling
Reports
Anonymous's avatar
3 years ago
Anonymous Do you still need more info? Thanks!
Completed Ideas
  • Set as landing page feature missing in Apr 2026 update (Build 2.153.1206.0) both in Desktop and Serv
  • Input Slicer Bug: Cursor jumps to position 0 and values cannot be cleared in Service
  • Input Slicer Causing Browser Tab Freeze in Public Links (Started April 24, 2026)
  • Small multiples not fitting to scale
  • Previously working Mac calender visual now gives me a error every time I touch it!
  • Text Slicer does not reset via Bookmarks or Clear All in Power BI Service (Service-only behavior)
  • Text Input Slicer is not reset by bookmarks in Power BI Service while working correctly in Power BI
  • Azure maps not displaying mapped data points in publish to web when location used
  • Azure Maps reference layer transparency behaves differently after publishing to Power BI Service
  • Desktop Application Bug?? - PBI desktop application left navigation icons always solid black
  • © 2026 Microsoft
  • Privacy & cookies
  • Terms of use
  • Trademarks
Your Privacy Choices Consumer Health Privacy
Share this pageShare on LinkedInShare on FacebookShare on XShare on RedditShare on BlueskySubscribe via RSSShare via email
