JyotiAdhav1976
3 months agoRegular Visitor
Status:
New
Enable Power Query editing for Power BI Semantic Model connections in Excel for changes
Currently, Excel allows connection to Power BI semantic models primarily through PivotTables. While limited editing is technically possible, it requires the use of DAX queries, which is not user-friendly for most business users.
Unlike SQL Server or other sources, there is no simple way to:
- Edit existing connections
- Filter columns or rows
- Shape data using Power Query
This creates a usability gap, especially for users who rely on Excel for flexible data preparation.
Suggestion
Provide the ability to edit Power BI semantic model connections using Power Query instead of DAX, enabling:
- Easy editing of existing connections via Power Query Editor
- Column selection and filtering through UI (no DAX required)
- Standard transformations (filter, merge, append, reshape)
- Save and refresh refined queries
No CommentsBe the first to comment
Recent ideas
Expose Power Query as a Standalone Runtime and Command-Line Interface (CLI)
Summary Power Query has evolved into one of Microsoft's most powerful data transformation technologies and is now used across Excel, Power BI, Fabric, Dataflows, Power Platform, and other products. ...juansgr_16 minutes agoNew MemberNew2Views0likes1CommentExpose User Prompt and Agent Response Logs for Fabric Data Agents
Idea: As an engineer responsible for managing and improving Microsoft Fabric Data Agents, I currently have no way to view how users are interacting with the agents I’ve built. While it’s likely that...JoshuaPitzer1 hour agoAdvocate INew1.2KViews26likes2CommentsImprove relationship visualisation in Model View for large semantic models.
When working with complex models containing many fact and dimension tables, relationship lines frequently cross and overlap, making lineage difficult to follow. A useful enhancement would be to allo...jcheeseaos2 hours agoNew MemberNew3Views0likes0CommentsEnable Export and Programmatic Access to Copilot Narrative Text
Copilot Narratives provide valuable AI-generated insights directly within Power BI reports. However, there is currently no straightforward way to export, copy, or programmatically retrieve the exact ...Mario_A_S_13 hours agoNew MemberNew22Views3likes0Comments
