RAMUK1
11 years agoNew Member
Status:
Completed
Allow runtime parameters in Power View and/or Power Query
PowerView does not take input parameters at run time. In order to change the data being presented at runtime the user must use a filter or the query author must use a non-deterministic function in t...
gowthamveera
Advocate II
6 years agoany update on this ?
Recent ideas
- fbcideas_migusr11 minutes agoNew MemberNew319Views9likes3Comments
Favorites, recent fields and field groups in the Data pane (large models)
On big models the Data pane is a pain. Search helps, but you keep searching the same stuff again and again. And when a lot of fields have almost the same name (UN, UN METAS, UN_corr, UNIDAD_NEGOCIO…)...WildAnalyst39 minutes agoNew MemberNew2Views0likes0CommentsAllow Workspace Admins to View Power BI Semantic Model Configuration Without Requiring Take Over
a { text-decoration: none; color: #464feb; } tr th, tr td { border: 1px solid #e6e6e6; } tr th { background-color: #f5f5f5; } Description As a Power BI Workspace Administrator, I understand why own...LeonardGreene2 hours agoNew MemberNew6Views0likes0CommentsOpen Fabric notebooks in View‑only by default
Problem: Developers and reviewers with edit permissions frequently open notebooks for reading. Notebooks currently open in edit mode with autosave, which causes accidental changes and noisy version h...AMD07913 hours agoAdvocate IVNew336Views11likes1Comment
