RAMUK1
11 years agoNew Member
Status:
Completed
Allow runtime parameters in Power View and/or Power Query
PowerView does not take input parameters at run time. In order to change the data being presented at runtime the user must use a filter or the query author must use a non-deterministic function in t...
ducthai
6 years agoNew Member
Miguel how can you mark this as completed, IMCOMPLETED we need user input box so end user can type in or select value or text and then run the report on run time. It is not possible to do it in power bi destop as of today.
Recent ideas
Favorites, recent fields and field groups in the Data pane (large models)
On big models the Data pane is a pain. Search helps, but you keep searching the same stuff again and again. And when a lot of fields have almost the same name (UN, UN METAS, UN_corr, UNIDAD_NEGOCIO…)...WildAnalyst25 minutes agoNew MemberNew2Views0likes0CommentsAllow Workspace Admins to View Power BI Semantic Model Configuration Without Requiring Take Over
a { text-decoration: none; color: #464feb; } tr th, tr td { border: 1px solid #e6e6e6; } tr th { background-color: #f5f5f5; } Description As a Power BI Workspace Administrator, I understand why own...LeonardGreene2 hours agoNew MemberNew6Views0likes0CommentsOpen Fabric notebooks in View‑only by default
Problem: Developers and reviewers with edit permissions frequently open notebooks for reading. Notebooks currently open in edit mode with autosave, which causes accidental changes and noisy version h...AMD07912 hours agoAdvocate IVNew335Views11likes1CommentService principal authentication support for data sources in Paginated(RDL) reports
We are only seeing two options(Basic, OAuth2) for data source authentication in a paginated report, Recently we see that the Service principal authentication enabled for Power BI(PBIX) reports, simi...Thatikonda_Vams3 hours agoNew MemberNew136Views6likes2CommentsMetadata-Driven Copy Job Control at Table and Column Level
We currently achieve metadata-driven table and column selection in Copy Data activities by using dynamic queries. This allows us to dynamically determine which tables and columns should be processed ...Motasim098 hours agoNew MemberNew6Views0likes0Comments
