RAMUK1
11 years agoNew Member
Status:
Completed
Allow runtime parameters in Power View and/or Power Query
PowerView does not take input parameters at run time. In order to change the data being presented at runtime the user must use a filter or the query author must use a non-deterministic function in t...
mark40
6 years agoNew Member
Could you use the filers attribute to achieve this? https://powerbi.microsoft.com/en-us/blog/power-bi-api-updates-roundup/ (see at the bottom)
Recent ideas
Allow the target pipeline reference in Invoke Pipeline / ExecutePipeline to be set dynamically
Problem Today, the Invoke Pipeline activity (and legacy ExecutePipeline) requires picking the target pipeline statically at design time — a fixed Workspace/Pipeline selection in the UI, which serial...JONATHANHAUN10 hours agoNew MemberNew8Views0likes0CommentsReset Bookmark Navigator Selection to the Default Published View on Browser Refresh
In Power BI Service, when a user selects a bookmark through a Bookmark Navigator, the bookmark identifier is appended to the report URL. If the user refreshes the browser page, the report reloads in ...vivek1234411 hours agoMicrosoft EmployeeNew6Views0likes0CommentsSeparate Interactive and Background Compute Allocation to Prevent Throttling of Live Reports
Problem Statement When Fabric capacity utilization reaches or exceeds 100% in the last one-hour window, end users experience significant disruptions when accessing Power BI Fabric live reports. This...TilakArani12 hours agoNew MemberNew8Views0likes0CommentsAccessibility issue in the Share dialog of embedded Power BI reports
Accessibility issue in the Share dialog of embedded Power BI reports I would like to share an accessibility finding identified while testing an embedded Power BI report published as part of the cont...ugartema12 hours agoAdvocate INew112Views15likes1Comment- fbcideas_migusr14 hours agoNew MemberUnder Review387Views12likes4Comments
