RAMUK1
11 years agoNew Member
Status:
Completed
Allow runtime parameters in Power View and/or Power Query
PowerView does not take input parameters at run time. In order to change the data being presented at runtime the user must use a filter or the query author must use a non-deterministic function in t...
kazlik
Helper II
6 years agoGreat news about this feature, was just being asked if I could do this today
Recent ideas
Preserve Background Colors When Exporting Power BI to Excel
When exporting a Power BI table or matrix to Excel, the data is exported correctly, but background colors and conditional formatting used to distinguish records are not preserved. It would be helpful...surya338 minutes agoNew MemberNew2Views0likes0CommentsAdd an option to hide all visual-level filters
As a best practice, we often need to hide fields and measures from the Filters pane in Power BI reports. When a visual contains dozens of fields and measures, manually hiding each one individually ca...Roman20261 hour agoNew MemberNew19Views0likes2CommentsPower BI Table visual – "Show items with no data" causes blank values
A table visual groups only on columns (no measures) from a parent table and its child table, with "Show items with no data" on. For parent rows that have no child rows, the parent row appears, but an...ratcowboy2 hours agoNew MemberNew15Views1like0Comments
