March 31 - April 2, 2025, in Las Vegas, Nevada. Use code MSCUST for a $150 discount! Early bird discount ends December 31.
Register NowBe one of the first to start using Fabric Databases. View on-demand sessions with database experts and the Microsoft product team to learn just how easy it is to get started. Watch now
We have muti tenant DB, with PowerBI Embedded - in order to run the report for each tenant, my uderstanding is we have to clone the report, then set the connection string. When we do this, the connection string does not change, but we receive no errors - see code below:
CloneReportRequest cloneReportRequest = new CloneReportRequest()
Name = $"{newReportName}-{Host}"
report = client.Reports.CloneReportInGroupAsync(groupID, report.Id, cloneReportRequest).Result;
var dsnArray = hostDataRepository.Get(Host).DSN.Split(':')[1].Split(';');
var datasource = dsnArray[0];
var initialCatalog = dsnArray[3].Split('=')[1];
ConnectionDetails connectionDetails = new ConnectionDetails()
ConnectionString = $"data source={datasource};initial catalog={initialCatalog}; persist security info=False"
var setConnections = client.Datasets.SetAllDatasetConnectionsInGroupAsync(groupID, report.DatasetId, connectionDetails).Result;
So it appears the issue is more complicated - it turns out the data connection is changing but it apparently takes a bit of time to see. However, the issue is that when you clone the report, it uses the same data set that is in the original report for the resulting report. So when you change the data connection for the resulting report, you are changing it for all the reports that you copied for each tenant from the base report. This is not the desire result - we want to clone the report with a clone of the data set so that when we change the connection for the report it is unique to that report. The high level is that we are trying to create reports for every tenant (becuase we cant change the connection uniquely on the fly), and each tenant has their own Database. Is there a better approach to this problem? Right now we are stuck with manually copying every report and manually setting all the data set/connections - not a good solution at all.
Your insights matter. That’s why we created a quick survey to learn about your experience finding answers to technical questions.
Arun Ulag shares exciting details about the Microsoft Fabric Conference 2025, which will be held in Las Vegas, NV.
6 | |
3 | |
3 | |
2 | |
2 |
