314mp_M0th4
Resolver I
Resolver I
Using power automate to detect changes in Power BI dataset and send email to owner
Hello. I have a table with four columns : type, amount 1, amount 2 and difference. If the difference exceeds 0 I want Power automate to send me an email. I can't use dashboard alerts for this problem. Is there any way to do this with connectors in Power automate?
Thanks.
Hi @314mp_M0th4 ,
Please try to use Data Activator, hope it is helpful for you.
For more details, you could read related document: Introduction to Data Activator - Microsoft Fabric | Microsoft Learn
Best regards,
Community Support Team_Binbin Yu
PijushRoy
Hi @314mp_M0th4
Please find the tutorial
Setup Data Alerts via Email using Power BI & Power Automate // Beginners Guide to Power BI in 2021 (...
Let me know if that works for you
If your requirement is solved, please mark THIS ANSWER as SOLUTION ✔️ and help other users find the solution quickly. Please hit the Thumbs Up 👍 button if this comment helps you.
Pijush
Linkedin
Appreciate your Like/Kudos
Hi, using tiles on a dashboard is NOT sufficient for my problem. I have to compare hundreds of values and if any one of them differ I have to send an alert.
Hi @314mp_M0th4 ,
Best regards,
