awtahhan
Replace column values using Uri.parts function
I have a column with encoded URL values, I want to decode and replace these values using Uri.parts function, to do so I constructed the following poqwer query:
Table.ReplaceValue(#"Renamed Columns3", each [url], Uri.Parts(Table.Column(#"Renamed Columns3","url"))[Query][a], Replacer.ReplaceValue, {"url"})
But I am getting the following error:
Expression.Error: We cannot convert a value of type List to type Text.
Details:
Value=[List]
Type=[Type]
Could any one please help me with this problem?
Thanks in advance.
PhilipTreacy
Hi @awtahhan
Download example PBIX file
The initial error you posted stated We cannot convert a value of type List to type Text. so I expected that your url column contains Lists somewhere like this
To avoid that error you can use try..otherwise when creating your Custom Column in Power Query like this
try Uri.Parts("http://contoso?a=" & [url])[Query][a] otherwise [url]
which gives this result
Check my file above for the full code example.
Regards
Phil
Did I answer your question? Then please mark my post as the solution.
If I helped you, click on the Thumbs Up to give Kudos.
Blog :: YouTube Channel :: Connect on Linkedin
PhilipTreacy
Hi @awtahhan
Regards
Phil
PhilipTreacy
Hi @awtahhan
The column you're trying to decode contains Lists.  Can you please supply some sample data to help me see what youu are working with.  I need to know what is in those Lists.
Regards
Phil
Hi @PhilipTreacy
Thanks for your reply, please find below screenshot. The column does not hold full URL, it is only holding the encoded query parameter values. I want to decode those query parameter values.
FabCon Global Hackathon
