I'm trying to calculate 2 running total colums for my business report on Power BI
1. Running total by project and date
2. Running total by date (all projects or the one filtered)
Here's an exemple on Excel (red colums):
Thanks !
Hi @jaygtt,
In your scenario, you can go to Query Editor, create a Index column from 1,
Then create calculated columns below:
Project comul = CALCULATE(SUM(Table1[Revenues]),FILTER('Table1','Table1'[Project]=EARLIER(Table1[Project]) && 'Table1'[Date]<=EARLIER(Table1[Date])))
Division cumul = CALCULATE(SUM('Table1'[Project comul]),FILTER('Table1','Table1'[Index]<=EARLIER(Table1[Index])))
Qiuyun Yu
Hi @jaygtt,
Qiuyun Yu
Thank you for the help !
Anyone ?
| 59 | |
| 43 | |
| 42 | |
| 23 | |
| 17 |
| 190 | |
| 122 | |
| 96 | |
| 66 | |
| 47 |
