Hi ,
For sample , i have the following data , Basically i have multiple columns where i need to take only selected columns and create a table out of it , I used summarize and extracted the columns I needed , But since its a table created using dax i cannot edit it in power query , so i need to use dax to unpivot columns and get my data as below. Please help
| EMP ID | Name | Country | Sales |
| 123 | Binay | India | 10 |
| 123 | Binay1 | Malaysia | 10 |
| 124 | Binay3 | Singapore | 11 |
| 125 | Binay4 | Thailand | 12 |
| 126 | Binay5 | Philliphines | 13 |
I want to have a table like below .
| EMP ID | Name | India | Malaysia | Singapore | Thailand | Philliphines |
| 123 | Binay | 10 | ||||
| 123 | Binay1 | 10 | ||||
| 124 | Binay3 | 11 | ||||
| 125 | Binay4 | 12 | ||||
| 126 | Binay5 | 13 | ||||
Hi @binayjethwa ,
Please try this formula of the calculated table.
Pivot Table =
VAR _tempTable =
ADDCOLUMNS (
'Table',
"@India",
SUM ( 'Table'[Sales] ),
FILTER (
'Table',
[EMP ID] = EARLIER ( 'Table'[EMP ID] )
&& [Name] = EARLIER ( 'Table'[Name] )
&& [Country] = "India"
"@Malaysia",
FILTER (
'Table',
&& [Country] = "Malaysia"
"@Singapore",
FILTER (
'Table',
&& [Country] = "Singapore"
"@Thailand",
FILTER (
'Table',
&& [Country] = "Thailand"
"@Philliphines",
FILTER (
'Table',
&& [Country] = "Philliphines"
VAR _selectColumns =
SELECTCOLUMNS (
_tempTable,
"Emp ID", [EMP ID],
"Name", [Name],
"India", [@India],
"Malaysia", [@Malaysia],
"Singapore", [@Singapore],
"Thailand", [@Thailand],
"Philliphines", [@Philliphines]
DISTINCT ( _selectColumns )
As you can see, I added a few rows to your sample data to show the sum up in the output.
Before:
After:
By the way, this conversion should be pivot, and unpivot is the case of the other way around.
Pivot and Unpivot with Power BI - RADACAD
Stephen Tao
You can use the matrix visual as follows:
If you need the countries sorted, you can add a sorting colum (preferably using a dimension table). Yoou can also turn off the subtotals/totals
Paul on Linkedin.
@PaulDBrown I will not be able to use matrix as i need to show around 25 fields in row section and i will have scroll issue, hence i need to use table visual only .
Try the below DAX code in calculated table,
Unpivot Table =
VAR _tempTable =
ADDCOLUMNS (
'Table (7)',
"@India", CALCULATE ( MAX ( 'Table (7)'[Sales] ), 'Table (7)'[Country ] = "India" ),
"@Malaysia", CALCULATE ( MAX ( 'Table (7)'[Sales] ), 'Table (7)'[Country ] = "Malaysia" ),
"@Singapore", CALCULATE ( MAX ( 'Table (7)'[Sales] ), 'Table (7)'[Country ] = "Singapore" ),
"@Thailand", CALCULATE ( MAX ( 'Table (7)'[Sales] ), 'Table (7)'[Country ] = "Thailand" ),
"@Philliphines", CALCULATE ( MAX ( 'Table (7)'[Sales] ), 'Table (7)'[Country ] = "Philliphines" )
SELECTCOLUMNS (
_tempTable,
"Emp ID", [EMP ID],
"Name", [Name ],
"India", [@India],
_selectColumns
Hi @Arul ,
I tried the same way , basically i have a large table , from which i need those columns and country wise sales . the output i receive is having multiple rows for each country , is there any way we can add all the values for that country and show as sum up value.
I want result in this way if there are multipe rows for particular column , it should sum up and display per emp , one row with sales value. Let me know if we can workaround this.
| 128 | Binay1 | 10 | ||||
| 126 | Binay5 | 13 |
Hi @binayjethwa ,
Pivot Table =
VAR _tempTable =
ADDCOLUMNS (
'Table',
"@India",
FILTER (
'Table',
"@Malaysia",
FILTER (
'Table',
"@Singapore",
FILTER (
'Table',
"@Thailand",
FILTER (
'Table',
"@Philliphines",
FILTER (
'Table',
SELECTCOLUMNS (
_tempTable,
"Emp ID", [EMP ID],
"Name", [Name],
"India", [@India],
Before:
After:
Stephen Tao
Hi @Anonymous
I am trying to create similar values in which i have few columns and i want to see if value in Key Figure column is equal to "Requested Sale Order" then it should only give me the values of two other coulmns called "Requested Shipped Order and "Requested Shipped Order Value" Similarly if key figure is equal to "Shipped Sales Order " then it should populate values of "Shipped Sales " and "Shipped Sales Order value " .
I try this in Matrix table but as soon as i enterd the values its showing me other columns as well ,please see below for better explanation :
My Desire Result is :
Request you to please help me if its possible:
Ashish
| 76 | |
| 36 | |
| 31 | |
| 29 | |
| 26 |
