Bhaskar_K1986's avatar
Bhaskar_K1986
4 years ago
Help required in Power BI for running total based on value passed
Hi Team,
I'm trying to do a running total for a column where I am supposed to add the column values based on the value passed.
Demand value= 73593        In excel we have used offset to get this value:
value passed =4        Cumulative sum           '=SUM(OFFSET(B1,1,0,4,1))
Sum of 4 rows value =126463                                                     Cumulative Average    '=Average(OFFSET(B1,1,0,4,1))
In Excel, we can get this value by just passing how many rows have to get the sum, but in Power BI I couldn't get that.
In the below example Required value is showing 126463 which is the sum of 4 rows based on the value passed is 4.
Suppose the value passed is 5 then it has to get a sum of 5 rows as the required value, where I could change the sum dynamically.
I hope someone would have come across this type of requirement. I need your help in getting the desired results.
1 Reply
  • v-xiaotang's avatar
    v-xiaotang
    Hi Bhaskar_K1986
    Thanks for reaching out to us.
    In the above example, I am not sure which is the original data and which is the expected result. So I created a simple example, could you give the expected output according to it? Thanks.
    Community Support Team _Tang
    If this post helps, please consider Accept it as the solution to help the other members find it more quickly.
