In my powerbi reports, i would like to visualize the table of similar products based on the selection of one particular product.
Similarity decisions should be taken based on the columns/criteria chosen.
Say example, below is the products table.
CriteriaFields table is the list of column names of Product table, usually.
Visual report, it is like below:
If i choose product C and in criteria fields Color, it should list other similar products which is same color as of Product C.
if i choose product C and in criteria fields Color & Size, it should list other similar products which is of same color and size as of Product C.
Can you please suggest me a better way to do it ?
I am not sure how your datamodel looks like, but I tried to create a sample pbix file like below.
Please check the below picture and the attached pbix file if it suits your requirement.
Color measure: =
IF (
HASONEVALUE ( Data[Product] ),
VAR _productselectlist =
VALUES ( 'Product'[Product] )
VAR _colorselectlist =
SUMMARIZE (
FILTER ( ALL ( Data ), Data[Product] IN _productselectlist ),
Data[Color]
VAR _sizeselectlist =
SUMMARIZE (
Data[Size]
SWITCH (
TRUE (),
SELECTEDVALUE ( Criteria[Criteria] ) = "Color", MAXX ( FILTER ( Data, Data[Color] IN _colorselectlist ), Data[Color] ),
SELECTEDVALUE ( Criteria[Criteria] ) = "Size", MAXX ( FILTER ( Data, Data[Size] IN _sizeselectlist ), Data[Color] ),
MAXX (
FILTER (
Data,
Data[Color]
IN _colorselectlist
&& Data[Size] IN _sizeselectlist
Data[Color]
Size measure: =
IF (
SUMMARIZE (
Data[Color]
SUMMARIZE (
Data[Size]
SWITCH (
TRUE (),
SELECTEDVALUE ( Criteria[Criteria] ) = "Color", MAXX ( FILTER ( Data, Data[Color] IN _colorselectlist ), Data[Size] ),
SELECTEDVALUE ( Criteria[Criteria] ) = "Size", MAXX ( FILTER ( Data, Data[Size] IN _sizeselectlist ), Data[Size] ),
MAXX (
FILTER (
Data,
Data[Color]
IN _colorselectlist
Data[Size]
This DAX is not generalised and is not working for any number of criteria items say, if the Criteria[Criteria] has more than 2 criterias and if multiple selection happens.
Say, if Criteria[Criteria] has 5 items called "color, size, manufactured by, marketed by, cost"
using the same dax script given, if we chose criteria as color, size, cost , how can i adapt the script for this kind ?
Color measure: =
IF (
SUMMARIZE (
Data[Color]
SUMMARIZE (
Data[Size]
SWITCH (
TRUE (),
MAXX (
FILTER (
Data,
Data[Color]
IN _colorselectlist
Data[Color]
Size measure: =
IF (
SUMMARIZE (
Data[Color]
SUMMARIZE (
Data[Size]
SWITCH (
TRUE (),
MAXX (
FILTER (
Data,
Data[Color]
IN _colorselectlist
Data[Size]
17 | |
8 | |
7 | |
6 | |
6 |
26 | |
13 | |
12 | |
9 | |
8 |
