Join the Fabric FabCon Global Hackathon—running virtually through Nov 3. Open to all skill levels. $10,000 in prizes! Register now.
Remove Duplicates Per Group (keep first) measure help
Hi All
Is it possible to create a measure in PBI that remove duplicate values per group, and keeps the first occurrence of the value? Perhaps not a measure but maybe a new table, I'm unsure of how to work around this. For context, the database I'm working with has a funky treatment of some data that has a function back-end but doesn't make sense when trying to visualise user behaviour.
Currently, the data looks like:
USERENTRY IDENTRYSTATUSTIME SUBMITTED (HH:mm:ss)
userA1unicornfail10:23:10
userA2forestpass10:30:49
userA1unicornfail10:30:49
userB1unicornfail13:40:22
userB1fairypass13:43:59
I want to clean it so it looks like:
Note the row I want to remove has
  1. duplicated ENTRY from the first instance for userA and
  2. duplicated TIME SUBMITTED from the first instance for userA
Also, the ENTRY ID cannot be used.
Any pointers would be greatly appreciated 🙂
2 ACCEPTED SOLUTIONS
Pragati11
Hi @Anonymous ,
Check if this existing thread helps:
https://community.powerbi.com/t5/Power-Query/Remove-duplicates-keeping-the-most-recent-row/m-p/757837
Pragati
Pragati Jain
MVP logo
LinkedIn | Twitter | Blog YouTube
Did I answer your question? Mark my post as a solution! This will help others on the forum!
Appreciate your Kudos!!
Proud to be a Super User!!
Here's the M code that does what you want:
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WKi1OLXJU0lEyBOLSvMzk/KI8ICstMTMHJGhgZWRsZWigFKuDUGkEks8vSi0uATIKEouLIQqNDaxMLFEU4jISVaUTTpXGViZA+40wVALliyqR7AaqM7YyBZoYCwA=", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [User = _t, EntryID = _t, Entry = _t, Status = _t, Time = _t]),
    #"Changed Type" = Table.TransformColumnTypes(Source,{{"User", type text}, {"EntryID", Int64.Type}, {"Entry", type text}, {"Status", type text}, {"Time", type time}}),
    #"Added Custom" = Table.AddColumn(#"Changed Type", "FirstTimeEntry",
        each List.Min(
            Table.SelectRows(
                #"Changed Type",
                (r) => r[User] = [User] and r[Entry] = [Entry]
            )[Time]
        ) = [Time]),
    #"Filtered Rows" = Table.SelectRows(#"Added Custom", each ([FirstTimeEntry] = true)),
    #"Removed Columns" = Table.RemoveColumns(#"Filtered Rows",{"FirstTimeEntry"})
    #"Removed Columns"
Best
D
        each List.Min(
            Table.SelectRows(
                #"Changed Type",
            )[Time]
        ) = [Time]),
    #"Removed Columns"
Best
D
Thanks @Anonymous, had to have a little play around and add in r[entry id] = [entry id] but it's working well now 👍 cheers again
Yeah... That's a perfect job for Power Query. You can do it in DAX as well as a calculated table but it really should be performed in PQ as this is the data-munging tool. I can create some sample M code for you so that you can see how such cleaning is done...
Best
D
Pragati11
Hi @Anonymous ,
Pragati
Pragati Jain
MVP logo
Thanks @Pragati11 , the buffer got me halfway there! Now it's just removing the wrong duplicate, hopefully the other reply will resolve this 🙂
