LotteLaugesen's avatar
4 years ago
Problem with running total
Hi
Can anybody tell me what's wrong with my running total? Why doesn't it aggregate when I have different Currency LCU?
Can anybody tell me how to solve it? When I remove Currency LCU there is no problem.
My calculation:
BR
Lotte
    • LotteLaugesen's avatar
      LotteLaugesen
      Icon for Helper V rankHelper V
      Hi tamerj1
      Thanks - It almost works πŸ™‚
      The first 2 lines are adding up, but below you can see that 2 other lines are not
      Have you got any more other ideas?
      • tamerj1's avatar
        tamerj1
        LotteLaugesen
        In this case use
        ALLSELECTED ( TableNam[Currency LCU] ) inside the CALCULATE function.
    Hi LotteLaugesen ,
    Please use ALLEXCEPT() function on [Current LCU]
    Acc. DKK Amount =
    VAR RT =
        IF (
            [DKK] <> BLANK (),
                'Misc calc'[DKK],
                ALLEXCEPT ( 'table', 'table'[Current LCU] ),
                FILTER (
                    ALLSELECTED ( 'Dim Calendar' ),
                    'Dim Calendar'[Date] <= MAX ( 'Dim Calendar'[Date] )
        RT
    Jay
        Hi LotteLaugesen ,
        Please share pbix so that we could test formula.
        Jay
