EM2
Problem with a POWER BI rolling formula (DAX)
Hi everyone 🙂
I have a table in PowerBI that has specific values for each month (Actual) and I have to create a measure that aggregates the values of the next 3 months rolling. But if any of the 3 values is blank, the formula should return a blank value. (so the blue value should be blank).
SKUMonthActual (qty)To be cleanAggregate 3 months rolling
71181November3.423 8.166
71181Dicember7651
71181January3.978
I have created these 2 formulas, but they are not working:
Actual Cleaned =
VAR MaxDate= MAX(Lut_Calendar[Data Calendar])
return
CALCULATE(
SUM(Drop_Forecast[Actual]),FILTER(Drop_Forecast,Drop_Forecast[to be clean]<>1)
Actual 3M cleaned =
return
IF([Actual Cleaned]<>BLANK(),
CALCULATE(
SUMX('Drop_Forecast 3M',[Actual Cleaned])
FILTER(
ALL(Lut_Calendar[Data Calendar]),
AND(
Lut_Calendar[Data Calendar]<=MaxDate,
DATEADD(Lut_Calendar[Data Calendar],3,MONTH)>MaxDate
),BLANK())
Thanks for your help! 🙂
Hi @EM2 ,
How is 8.166 calculated? The sum of 3.423,765 and 3.978 is not 8.166.
And also, you may have a date column in your table, right?
Stephen Tao
