LeszekGL
Problem with Total sales calculation - please help
Hello everyone
I am having a problem getting the correct sales total.
In the example below, I am calculating the sales total from the beginning of each month to the 10th of the month.
But at the aggregate business unit and year level, and the totals are as for whole months
Thank you in advance for your help !!
Hi @LeszekGL ,
Based on your description, I created these data.
Create MEASURE.
MEASURE =
VAR _mindate =
    EOMONTH ( MIN ( 'Table'[Date] ), -1 ) + 1
VAR _maxdate =
    EOMONTH ( MAX ( 'Table'[Date] ), -1 ) + 10
VAR _sum1 =
        SUM ( 'Table'[Amount] ),
        'Table'[Date] >= _mindate
            && 'Table'[Date] <= _maxdate
    _sum1
Measure 2 =
SUMX('Table',[MEASURE])
Measure 3 =
IF(HASONEVALUE('Table'[Date].[Month]),[MEASURE],[Measure 2])
If your Current Period does not refer to this, please clarify in a follow-up reply.
Clara Gong
If there is any post helps, then please consider Accept it as the solution  to help the other members find it more quickly.
Hi @LeszekGL ,
Create MEASURE.
MEASURE =
VAR _mindate =
VAR _maxdate =
VAR _sum1 =
    _sum1
Measure 2 =
Measure 3 =
Clara Gong
Hello Clara
Works fine - thanks a lot !!!
Leszek
Greg_Deckler
@LeszekGL First, please vote for this idea: https://ideas.powerbi.com/ideas/idea/?ideaid=082203f1-594f-4ba7-ac87-bb91096c742e
This looks like a measure totals problem. Very common. See my post about it here: https://community.powerbi.com/t5/DAX-Commands-and-Tips/Dealing-with-Measure-Totals/td-p/63376
Also, this Quick Measure, Measure Totals, The Final Word should get you what you need:
https://community.powerbi.com/t5/Quick-Measures-Gallery/Measure-Totals-The-Final-Word/m-p/547907
Also: https://youtu.be/uXRriTN0cfY
And: https://youtu.be/n4TYhF2ARe8
Follow on LinkedIn
External Tools: MSHGQM
Latest book!:
DAX For Humans
