MickeLearnPBI
Problem with Switch and more than... Any ideas?
I have tried to do a dax with switch but does not seem to be working with value under och over.
Anyone have any ideas to do it better?
[Status] =
SWITCH(
TRUE(),
'table'[InvestigationID] = 0 && 'table'[DecisionID] > 0, "Notification One - investigation not opened",
'table'[DecisionID] = > 0, "Notification two - Decision not to open investigation",
'table'[InvestigationID] = > 0, "Actualizations processed",
'table'[InvestigationID] = 0, "New actualizations",
"Closed actualizations"
Thanks for the reply from @Jihwan_Kim , please allow me to provide another insight:
Hi @MickeLearnPBI ,
Based on your description, the calculated column created, refer to the following:
Status =
SWITCH(
    TRUE(),
    Notifications[InvestigationID] = 0 && Notifications[DecisionID] > 0, "Notification One - investigation not opened",
    Notifications[DecisionID] > 0, "Notification two - Decision not to open investigation",
    Notifications[InvestigationID] > 0, "Actualizations processed",
    Notifications[InvestigationID] = 0, "New actualizations",
Adamk Kong
Hi @MickeLearnPBI ,
Status =
SWITCH(
    TRUE(),
Adamk Kong
Thanks! That worked like a charm 👍
Jihwan_Kim
Hi, I guess you are trying to create a calculated column?
Please try something like below whether it suits your requirement.
[Status] =
SWITCH (
    TRUE (),
    'table'[DecisionID] >= 0, "Notification two - Decision not to open investigation",
    'table'[InvestigationID] >= 0, "Actualizations processed",
If this post helps, then please consider accepting it as the solution to help other members find it faster, and give a big thumbs up.
Click here to visit my LinkedIn page
Click here to schedule a short Teams meeting to discuss your question.
That almost worked. It seems that when I use this below i only get the two first results in the new column =
[Status] =
SWITCH (
    TRUE (),
Can i get all results in the same column somehow?
I do not know well about your business logic, but please try writing down all conditions... something like below?
[Status] =
SWITCH (
    TRUE (),
    'table'[InvestigationID] < 0
        && 'table'[DecisionID] >= 0, "Notification two - Decision not to open investigation",
        && 'table'[DecisionID] < 0, "Actualizations processed",
        && 'table'[DecisionID] < 0, "New actualizations",
