Total nebie and not a developer, have done extensive googling as well as searching the forum here to no avail, but here we go;
I´m trying to create a measure for DATEDIFF between two columns containing timestamps in the same table, but it´s failing and it seems to be based on some rows containing NULL-values.
The statement is simple:
Measure = DATEDIFF(TABLE[column],TABLE[column], HOUR))
Is there a way to filter out the rows containig NULL values directly in the query?
Br
/Micke
@Anonymous , Try a new column like
Measure = if(not(isblank([column1])) && not(isblank([column2])) , DATEDIFF(TABLE[column1],TABLE[column2], HOUR) , blank())
Thanks amitchandak, this solved my issue, great!!!
Br
/Micke
| 9 | |
| 3 | |
| 3 |
| 13 | |
| 9 | |
| 8 | |
| 8 | |
| 7 |
