Get registeredGet Fabric Certified for FREE during Fabric Data Days. Don't miss your chance! Learn more
Good Mornig all,
I have a doubt, Iknow I can either unpivot or create a column in M, but my problem is, that I need to have the data pivoted and some of the collumns come from a calculated column not from de dataset.
I have a N assets in the datast. sevreal columns give us diferent valuations for that asset (appraisal, appraisal2, appraisal3, appraisal4 market value, etc)
Therefore to get a variation of coeficient, I need to make a calculation that gets all the columns standard deviation and divide it by the average of their value.
Does enyone have an idea for this matter?
Many thanks
Borja Veiga
Hi @Borjaveigasvh
You can "unpivot" with dax as long as you don't expect dynamic creation of fields. Something like this will create a calcuated (unpivotted) table and from there on you can use the normal static functions.
UnPivotted =
GENERATE(
CROSSJOIN(
GENERATESERIES(1,5,1), // 5 the number appraisal fields you have
ALL('Table'[Asset])
var _Asset = 'Table'[Asset]
var _Field =
switch(
TRUE(),
[VALUE]=1,LOOKUPVALUE('Table'[f1],'Table'[Asset],_Asset), // your appraisal fields
[VALUE]=2,LOOKUPVALUE('Table'[f2],'Table'[Asset],_Asset),
[VALUE]=3,LOOKUPVALUE('Table'[f3],'Table'[Asset],_Asset),
[VALUE]=4,LOOKUPVALUE('Table'[f4],'Table'[Asset],_Asset),
[VALUE]=5,LOOKUPVALUE('Table'[f5],'Table'[Asset],_Asset)
return
ROW(
"FieldValue",_Field
Hi @Borjaveigasvh
UnPivotted =
GENERATE(
CROSSJOIN(
ALL('Table'[Asset])
var _Field =
switch(
TRUE(),
return
ROW(
"FieldValue",_Field
Hello JustJan I have to thank you, after implementing your solution, it does work!
I have some issues, because since the appraisals and values come from different tables,when In implement this formula :
Thanks so much, I'll start to implement this solution.
Sorry for the delay in answering.
Best
Borja
| 9 | |
| 5 | |
| 3 | |
| 3 |
| 23 | |
| 12 | |
| 11 | |
| 9 | |
| 8 |
