Power BI Dax help
Anonymous ,
a new column in temp1
Column 1 = CALCULATE(SUM(#Temp2[tot_amt]), FILTER(ALL(#Temp1), eomonth(#Temp2[disb_dt],0) = eoMONTH(#Temp1[app_dt],0) && #Temp2[app_id]= #Temp1[id]))
this should work as a measure if they are joined on id and app_id
CALCULATE(SUM(#Temp2[tot_amt]), FILTER(ALL(#Temp2), MONTH(#Temp2[disb_dt]) = MONTH(#Temp1[app_dt]) && YEAR(#Temp2[disb_dt]) = YEAR(#Temp1[app_dt])))
relationship is already defined at the Model between Id = app_Id.
So I was trying to create Measure under Table1 data_set but it is throwing me an error:-
A single value for column 'app_dt' in table '#Temp1' cannot be determined. This can happen when a measure formula refers to a column that contains many values without specifying an aggregation such as min, max, count, or sum to get a single result.
