I have a formula that I'm trying to figure out but so far have been unsuccessful.
I'm trying to calculate the total budget across all departments, using the following logic:
Sum of all Total Budgets Per Dept ID where Total Budget Per Dept ID = Max of Shared Budget + Separate Budget
For example, the total budget for Dept ID 54321 is 300,000 (the max of the shared budgets of 200,000 plus the separate budget of 100,000).
Dept ID | Structure | Budget | Employee |
12345 | Separate | 100,000 | Kim |
12345 | Separate | 100,000 | John |
54321 | Shared | 100,000 | Chris |
54321 | Shared | 200,000 | Ashley |
54321 | Separate | 100,000 | Kelly |
Any help would be appreciated! Thanks so much.
Hi, @PBINovice123
Please try the following methods.
Total budget =
MAX ( 'Table'[Budget] ),
FILTER (
'Table',
[Dept ID] = EARLIER ( 'Table'[Dept ID] )
&& [Structure] = "Shared"
+ CALCULATE (
SUM ( 'Table'[Budget] ),
FILTER (
'Table',
&& [Structure] = "Separate"
Is this the result you expect?
Hi, @PBINovice123
Total budget =
FILTER (
'Table',
+ CALCULATE (
FILTER (
'Table',
You can replace Null easily with
For the first one I am not facing such issues, maybe you have more number of columns there, I need to see the exact sample data-set
Also please check again if you are giving the filter below
Max Shared Budget per ID = CALCULATE(max(Sheet2[Budget]),ALLEXCEPT(Sheet2,Sheet2[Dept ID ],Sheet2[Structure]),Sheet2[Structure]="Shared")
Mark my post as a solution if it helped you| Munde and Kudis (Ladies and Gentlemen) I like your Kudos!! !!
My YT Channel Dancing With Data !! Connect on Linkedin !!Power BI for Tableau Users
Thanks a lot, but unfortunately it still isn't computing as intended.
One thing I noticed is that the "Shared Budget per ID" formula is giving me a value even if none of the structures within the field are "Shared".
Additionally, I failed to mention that some of the values in the "Structure" column are blank and should be treated like a Separate structure. Do you know how I would account for all of this?
Thanks again!
Step 1
Here is my video on ALL,ALLEXCEPT function https://youtu.be/fEIaJigVfFg if you wish to see
Ritesh
12 | |
12 | |
10 | |
9 | |
9 |
