Hello Fabric Community,I need some help with a problem I'm facing in Power BI. I'm using a matrix visual and I want to show individual values from a column (0-1) without summing them up. I used this DAX formula to create a measure:
dax
VAR SelectedValue = SELECTEDVALUE('T&S Table_2'[(0-1)])
RETURN IF(ISBLANK(SelectedValue), 0, SelectedValue)
This measure works well for displaying the data, but the subtotals are not adding up correctly; they just show as 0. I need the subtotals to correctly sum up the values at each level of the hierarchy.
Sample Input Data
Below is a sample of the data from 'Table_2':
-Category A | |
Subcategory A1 | 100 |
Subcategory A2 | 200 |
-Category B | |
Subcategory B1 | 200 |
Subcategory B2 | 300 |
Subcategory B3 | 200 |
Matrix Visual Configuration
- Rows: categroies and subcategories
- Values: The measure based on the (0-1) column
Current Output with Issue
The matrix correctly displays the individual (0-1) values for each ID, but the subtotal is incorrectly showing as 0.
Matrix Visual:
-Category A | |
subtotal | 0 |
-Category B | |
subtotal | 0 |
Desired Output
I need the subtotal to accurately sum the individual (0-1) values:
-Category A | |
subtotal | 300 |
-Category B | |
subtotal | 700 |
subtotal (category Aand B comes under one section) | 1000 |
Does anyone have experience with this issue or any advice on how to fix the subtotal calculation in the matrix? Any suggestions would be really helpful.Thanks in advance for your help!
Best regards,
vs24
Looks like your source data may not be in the right format. Try this instead
Then the matrix visual creates itself.
Or if you want the totals at the bottom
| 3 | |
| 2 | |
| 2 | |
| 2 | |
| 1 |
