Need Help finding a solution for percentage of totals
I need to find the percentage of each providers total units per Proccode for 2024.
For Example: if Dr Doe had 1 unit for proccode 9921 and 3 units for 9922.
it would be 25% for 99202 and 75% for 99203.
How can I get my table to display this? I tried using "show value as" bt it only shows the percentage of the grand total. When I am needing the percentage of each indiviual providers total.
vicky_
I have my table setup like the above, and then created  a measure:
Percentage of Total per Provider =
var denominator = CALCULATE(COUNTROWS('Table'), REMOVEFILTERS('Table'[Postcode]))
var numerator = COUNTROWS('Table')
return DIVIDE(numerator, denominator)
And then the result looks something like:
If that isn't what you want, please provide some sample data with any sensitive info removed so that we can provide more specific help.
Here some sample data. I have thousands of rows of data so I am not able to recreate the table you have.
https://www.dropbox.com/scl/fi/yl0prxe9t1k4t21tsw1m6/CPT-Volumes-Graphs-Copy.pbix?rlkey=6mk6m9kfwipp...
