My calculation does not work using variable (row context issue or something else?)
- 5 years ago
How about this for the variable:
Var vNotEligibleStep1 = COUNTROWS( FILTER( Data, Data[Consent] = "Not Eligible" && Data[Step] = 1 ) )This will return 1 for each row which meets the filtered criteria. You can now keep the switch function clause.
- 5 years ago
Alternatively you can try:
new measure = SUMX(Data, [Step 1_0819])
PaulDBrown Actually, SUMX made more output of rows, so I think it might not be the solution, but I need to review data more. Thank you so much for all your help.
Can you post the updated PBIX file? Maybe we can take it step by step.
- JustinDoh15 years ago
Post Prodigy
PaulDBrown here is a link to the updated Pbix file. I guess I am leaning toward using SUMX (on this particular small data).
But, when I use other larger datasets (for other column, but with same approach (using Countrows --> SUMX), instead of showing 1, it shows as 2 occurrences. I guess there are duplicate occurrences with same condition. What should I do? How can I make the dinstinct (SUMX)?
Post Prodigy
PaulDBrown I have created a new question regards to SUMX. I am really struggling to find the solution for getting Total on the bottom of Matrix because if use SUMX, it creates multiple output (rather than 1), but when I use SUMX, Total comes out to be "" (when I have to exclude anything).
