yaguaso
Measurements in a single column with 9 values, Power BI
Hello community. I am trying to show the values of nine measurements [Ai=1..,9 Variable] in a single column, as show:
 but I get an error, in line 14, with the variable posic, after using the following formula:
1 MOSTRAR_ACTIV = SUMX(ACTIVIDADES,
2 VAR _Indx =[POSICION]
3 VAR posic =
4 IF(_Indx = 1, [A1 Variable],
5 IF(_Indx = 2, [A2 Variable],
6 IF(_Indx = 3, [A3 Variable],
7 IF(_Indx = 4, [A4 Variable],
8 IF(_Indx = 5, [A5 Variable],
9 IF(_Indx = 6, [A6 Variable],
10 IF(_Indx = 7, [A7 Variable],
11 IF(_Indx = 8, [A8 Variable],
12 IF(_Indx = 9, [A9 Variable],
13 SWITCH( TRUE(),
14 IF(_Indx<=9, posic
I tried with another formula:
1 MOSTRAR_ACTIV =
2  SWITCH (
3         SELECTEDVALUE(ACTIVIDADES[POSICION]),
4        1, [A1 Variable],
5        2, [A2 Variable],
6        3, [A3 Variable],
7        4, [A4 Variable],
8        5, [A5 Variable],
9        6, [A6 Variable],
10       7, [A7 Variable],
11       8, [A8 Variable],
12       9, [A9 Variable],
13       150
14 )
No errors, but show only the value 150 of line 13.
Could someone help me determine what is wrong?
Thanks, before hands
Hi  @yaguaso ,
You can change the dax to the following form:
Column =
SWITCH(
    'Table'[POSICION],
    1,[A1 Variable],
    2,[A2 Variable],
    3,[A3 Variable],
    4,[A4 Variable],
    5,[A5 Variable],
    6,[A6 Variable],
    7,[A7 Variable],
    8,[A8 Variable],
    9,[A9 Variable],150)
Result:
Liu Yang
Hi  @yaguaso ,
Column =
SWITCH(
    'Table'[POSICION],
    1,[A1 Variable],
    2,[A2 Variable],
    3,[A3 Variable],
    4,[A4 Variable],
    5,[A5 Variable],
    6,[A6 Variable],
    7,[A7 Variable],
    8,[A8 Variable],
Result:
Liu Yang
I solved this problem using the following measure:
MOSTRAR_ACTIV =
 IF(HASONEVALUE(ACTIVIDADES[POSICION]),
SWITCH(VALUES(ACTIVIDADES[POSICION]),
 1, [A1 Variable],
 2, [A2 Variable],
 3, [A3 Variable],
 4, [A4 Variable],
 5, [A5 Variable],
 6, [A6 Variable],
 7, [A7 Variable],
 8, [A8 Variable],
 9, [A9 Variable],
 10
Thanks for the help
lbendlin
Please provide sample data that covers your issue or question completely, in a usable format (not as a screenshot).
Do not include sensitive information or anything not related to the issue or question.
If you are unsure how to upload data please refer to https://community.fabric.microsoft.com/t5/Community-Blog/How-to-provide-sample-data-in-the-Power-BI-...
Want faster answers? https://community.fabric.microsoft.com/t5/Desktop/How-to-Get-Your-Question-Answered-Quickly/m-p/1447...
