JamHam
Issue with Dax and calculating Difference in Minutes
I am running into an issue when building a difference measure for Minutes. Below are the calculations for building the Current/Previous/Current Vs. Previous Seconds.
Current_MTD_Seconds = TOTALMTD([Average_Seconds_Day],DATESMTD([Date]))
Previous_MTD_Seconds = CALCULATE([Average_Seconds_Day], PREVIOUSMONTH(DATESMTD([Date])))
CvsP_MTD_Seconds = [Current_MTD_Seconds]-[Previous_MTD_Seconds]
These calculations are behaving as expected and are displaying the correct numbers.
But when I convert the seconds to minutes using the following Dax measure. The Current vs Previous measure is giving the incorrect time.
Current_MTD_Minutes = FORMAT(INT(
IF(MOD([Current_MTD_Seconds],60)=60,0,MOD([Current_MTD_Seconds],60)) +
IF(MOD(INT([Current_MTD_Seconds]/60),60)=60,0,MOD(INT([Current_MTD_Seconds]/60),60)*100) +
INT([Current_MTD_Seconds]/3600)*10000), "00:00")
Previous_MTD_Minutes = FORMAT(INT(
IF(MOD([Previous_MTD_Seconds],60)=60,0,MOD([Previous_MTD_Seconds],60)) +
IF(MOD(INT([Previous_MTD_Seconds]/60),60)=60,0,MOD(INT([Previous_MTD_Seconds]/60),60)*100) +
INT([Previous_MTD_Seconds]/3600)*10000), "00:00")
CvsP_MTD_Minutes = FORMAT(INT(
IF(MOD([CvsP_MTD_Seconds],60)=60,0,MOD([CvsP_MTD_Seconds],60)) +
IF(MOD(INT([CvsP_MTD_Seconds]/60),60)=60,0,MOD(INT([CvsP_MTD_Seconds]/60),60)*100) +
INT([CvsP_MTD_Seconds]/3600)*10000), "00:00")
For CvsP_MTD_Minutes I would expect the value to be -00:05. But it is giving me a value of -40:45.
This is my first time working with Power BI and Time calculations. So not sure where to start to troublshoot this issue.
Thank you,
Greg_Deckler
@JamHam See if this helps: Chelsie Eiden's Duration - Microsoft Fabric Community
Follow on LinkedIn
External Tools: MSHGQM
Latest book!:
DAX For Humans
Greg_Deckler
Follow on LinkedIn
Latest book!:
DAX For Humans
@Greg_Deckler - Thank you so much! This worked perfectly for what I was looking to accomplish.Minutes_Duration.png
