apelleti
Help with a DAX formula for Power BI measure
Hi everyone! Hoping some can help me with a DAX formula for a measure in Power BI.
In this scenario, lines are made up of segments. Lines can contain significant segments. I need a formula that checks if a line contains at least one significant segment and if it does, return the sum of the lengths of the lines that contain significant segments.
So in the scenario below, it would be the sum of the lengths of lines 1, 2 and 4:
Total Line feet = 10 + 65 + 30
Total Line feet = 105
Any help would be greatly appreciated!
Line NameSegment Length (ft)SignificantLine Length (ft) (sum of segments)
12Yes10
12No10
15No10
11No10
210Yes65
215Yes65
220Yes65
220Yes65
33No7
34No7
49Yes30
414No30
47Yes30
FreemanZ
hi @apelleti
try to
1)create a measure with this:
SignificantLen=
VAR _table =
FILTER(
   SUMMARIZE(
         TableName,
         TableName[Line],
         TableName[Significant],
         TableName[Length]
   TableName[Significant] = "YES"
SUMX(_table, TableName[Length])
2) then plot any visual with this measure.
I tried and it worked like this:
Hi @apelleti ,
I have created a simple sample, please refer to my pbix file to see if it helps you.
Create 3 measures.
Measure =
MAXX(FILTER(ALL('Table'),'Table'[Line Name]=SELECTEDVALUE('Table'[Line Name])),'Table'[Significant])
Measure 2 = sUMX(FILTER(ALL('Table'),'Table'[Line Name]=SELECTEDVALUE('Table'[Line Name])),'Table'[Segment Length (ft)])
SignificantLen =
var _1=SUMX(FILTER(ALL('Table'),'Table'[Line Name]=SELECTEDVALUE('Table'[Line Name])),'Table'[Segment Length (ft)])
var _2=SUMMARIZE('Table','Table'[Line Name],"aaa",[Measure 2])
var _3=CALCULATE(SUM('Table'[Segment Length (ft)]),FILTER(ALL('Table'),[Measure]="No"))
return
IF(HASONEVALUE('Table'[Line Name])&&[Measure]="Yes",[Measure 2],IF([Measure]="No",BLANK(),SUMX(_2,[aaa])-_3))
If it does not help, please provide more details with your desired output and pbix file without privacy information (or some sample data) .
Community Support Team _ Polly
apelleti
Thank you for your reply! I can't seem to get the right numbers. What formula did you use to calculate the line length from the segment lengths?
@apelleti I thought line length is native from your sample data. but it can be calculated.
@FreemanZ
I created it using:
Line Length (ft) = CALCULATE(SUM('Table'[Segment Length (ft)]),
         ALLEXCEPT('Table','Table'[Line Name]))
Does that seem right to you?
Thank you!
FreemanZ
hi @apelleti
try to
SignificantLen=
VAR _table =
FILTER(
   SUMMARIZE(
         TableName,
         TableName[Line],
         TableName[Length]
