Hi
I am writing a meaure to calculate %Change from Dec'23 to Mar'24 and display value on card. Using the below measure.
Along with this KPI, i have few more KPIs on the same report which will use the filter of the ReportingMonth.
I want below expression should not filter based on selected reporting month and do the calculation just by using reporting month value and defined values from preMY.
%Change_CYCM =
VAR _preMY = VALUE("2023-12-01")
VAR _preqty =
SUM ( 'Bugs'[BUGS_COUNT] ), FILTER(ALLSELECTED('Bugs'),
'Bugs'[ReportMonth]=_preMY)
VAR _curMY = VALUE("2024-03-01")
VAR _curqty =
FILTER (
ALLSELECTED ( 'Bugs' ),
'Bugs'[ReportMonth] = _curMY
DIVIDE ( _preqty-_curqty, _preqty )
Hi @manojk_pbi
@some_bih Thank you very much for your prompt reply, and here allow me to offer some suggestions.
Based on your screenshot, I noticed that ReportMonth does not appear to be a date type of data.
Could you please check the field type and make sure to ensure that it is a date type.
Here I define it as short date.
Create a measure.
%Change_CYCM =
var _preMY = DATE(2023, 12, 01)
VAR _preqty =
CALCULATE(
SUM('Bugs'[BUGS_COUNT]),
FILTER(
ALL('Bugs'),
'Bugs'[ReportMonth] = _preMY
var _curMY = DATE(2024,03, 01)
VAR _curqty =
CALCULATE(
FILTER(
ALL('Bugs'),
DIVIDE( _preqty - _curqty , _preqty)
Here is the result.
Nono Chen
Hi @manojk_pbi
Create a measure.
%Change_CYCM =
VAR _preqty =
CALCULATE(
FILTER(
ALL('Bugs'),
VAR _curqty =
CALCULATE(
FILTER(
ALL('Bugs'),
Here is the result.
Nono Chen
Hi @manojk_pbi without model and details it is hard to spot issue. Still, try v2
Thanks for your reply. It is not working. For better understanding here i am attaching sample and current data model image.
Bugs data
BUG_TYPE | Sum of BUGS_COUNT | DATE | PROJECT_NAME | ReportMonth |
Deferred | 3834 | Jan 24 | Project1 | Dec 23 |
L4 | 128 | Jan 24 | Project1 | Dec 23 |
Deferred | 3826 | Feb 24 | Project1 | Jan 24 |
L4 | 123 | Feb 24 | Project1 | Jan 24 |
Deferred | 3875 | Mar 24 | Project1 | Feb 24 |
L4 | 121 | Mar 24 | Project1 | Feb 24 |
Deferred | 3950 | Apr 24 | Project1 | Mar 24 |
L4 | 119 | Apr 24 | Project1 | Mar 24 |
Deferred | 269 | Jan 24 | Project2 | Dec 23 |
L4 | 4 | Jan 24 | Project2 | Dec 23 |
Deferred | 239 | Feb 24 | Project2 | Jan 24 |
L4 | 0 | Feb 24 | Project2 | Jan 24 |
Deferred | 235 | Mar 24 | Project2 | Feb 24 |
L4 | 0 | Mar 24 | Project2 | Feb 24 |
Deferred | 243 | Apr 24 | Project2 | Mar 24 |
L4 | 0 | Apr 24 | Project2 | Mar 24 |
Deferred | 366 | Jan 24 | Project3 | Dec 23 |
L4 | 18 | Jan 24 | Project3 | Dec 23 |
Deferred | 367 | Feb 24 | Project3 | Jan 24 |
L4 | 15 | Feb 24 | Project3 | Jan 24 |
Deferred | 382 | Mar 24 | Project3 | Feb 24 |
L4 | 14 | Mar 24 | Project3 | Feb 24 |
Deferred | 358 | Apr 24 | Project3 | Mar 24 |
L4 | 13 | Apr 24 | Project3 | Mar 24 |
Calender Table
MonthYear | Year | Quarter | Month | Day |
1/1/2023 0:00 | 2023 | Qtr 1 | January | 1 |
2/1/2023 0:00 | 2023 | Qtr 1 | February | 1 |
3/1/2023 0:00 | 2023 | Qtr 1 | March | 1 |
4/1/2023 0:00 | 2023 | Qtr 2 | April | 1 |
5/1/2023 0:00 | 2023 | Qtr 2 | May | 1 |
6/1/2023 0:00 | 2023 | Qtr 2 | June | 1 |
7/1/2023 0:00 | 2023 | Qtr 3 | July | 1 |
8/1/2023 0:00 | 2023 | Qtr 3 | August | 1 |
9/1/2023 0:00 | 2023 | Qtr 3 | September | 1 |
10/1/2023 0:00 | 2023 | Qtr 4 | October | 1 |
11/1/2023 0:00 | 2023 | Qtr 4 | November | 1 |
12/1/2023 0:00 | 2023 | Qtr 4 | December | 1 |
1/1/2024 0:00 | 2024 | Qtr 1 | January | 1 |
2/1/2024 0:00 | 2024 | Qtr 1 | February | 1 |
3/1/2024 0:00 | 2024 | Qtr 1 | March | 1 |
4/1/2024 0:00 | 2024 | Qtr 2 | April | 1 |
Bugs data
Calender Table
15 | |
12 | |
8 | |
7 | |
7 |
24 | |
21 | |
12 | |
10 | |
7 |
