arpost
Post Prodigy
Post Prodigy
Help! How do I summarize and get a running total using DAX?
Greetings, PBI community! Have an interesting conundrum and wanted to see if anyone could offer a solution. Here's the two parts of the scenario with an example.
Let's say I have a dataset set up as follows along with a standard Calendar table with a date column:
DateCustomerCallsReplies
9/1/2022Jane Doe10
9/1/2022Max Jones43
10/1/2022John Smith21
10/2/2022Jane Doe21
11/13/2022Max Jones74
11/13/2022John Smith41
Need #1: Most Recent Value per Customer
I want to write a measure that sums up a total using the most recent value for each customer. So if I wanted to sum up the Calls, the interim "table" would be as follows:
CustomerCallsMostRecentDate
Jane Doe210/2/22
John Smith411/13/22
Max Jones711/13/22
The measure's final total would be 13.
Need #2: Most Recent Value based on Date Context
As part of the above, I ALSO need to make sure that this is based on the date context in which the measure is calculated, meaning it only shows the most recent value as of the date in question. Basically, I need a running total using the most recent values.
So if I put the Date from the Calendar table and the total measure in a table, it would look something like this (explanation column added to clarify which dates are being used):
DateCalls[EXPLANATION]
11/9/228Jane (10/2), John (10/2), and Max (9/1)
11/10/228Jane (10/2), John (10/2), and Max (9/1)
11/11/228Jane (10/2), John (10/2), and Max (9/1)
11/12/228Jane (10/2), John (10/2), and Max (9/1)
11/13/2213Jane (10/2), John (11/13), and Max (11/13)
Hoping this makes sense. Any ideas would be greatly appreciated. I've been able to get #1 thanks to this article from EnterpriseDNA, and I've been able to get #2 on its own using this article from SQLBI but I can't get them merged into one calc. 😝
thank you for your feedback, and please check the attached pbix file if it suits your requirement.
If this post helps, then please consider accepting it as the solution to help other members find it faster, and give a big thumbs up.
Click here to visit my LinkedIn page
Click here to schedule a short Teams meeting to discuss your question.
Jihwan_Kim
Please check the below picture and the attached pbix file.
Most recent date: =
IF ( HASONEVALUE ( Customer[Customer] ), MAX ( Data[Date] ) )
Most recent call #: =
VAR _mostrecentdate = [Most recent date:]
    CALCULATE ( SUM ( Data[Calls] ), 'Calendar'[Date] = _mostrecentdate )
Calls accumulate by most recent calls: =
VAR _currentdate =
    MAX ( 'Calendar'[Date] )
VAR _currentdatecallnumbers =
    ADDCOLUMNS (
        DISTINCT ( Customer[Customer] ),
        "@lastdate", CALCULATE ( MAX ( Data[Date] ), 'Calendar'[Date] <= _currentdate )
        TREATAS ( _currentdatecallnumbers, Customer[Customer], 'Calendar'[Date] )
Greetings, @Jihwan_Kim! Thanks for the reply. That's really helpful.
Quick question: this requires that there is a separate dimension table (Customers). Any chance you know of a solution that can work on the data in the data table itself? To put it another way, is there a form of the above that would work with just a Calendar table and a Data table?
Boom! That worked like a charm. 😁 Thanks for the help. I'm trying to figure out a related (but somewhat different) issue over here (link) as well, so if you have any sage advice you could offer, that'd be appreciated,
