Greetings, community! Hope someone can help me figure out this DAX scenario. I've tried just about everything of which I can think (SUMX, Calculate, SelectedValue, etc.), and can't figure out a solution. It seems like this should be simple, but it is driving me crazy! Let me set the stage with a "simplified" example.
I have a matrix with a date from one table and need to show the total $ in that window of time in another table.
Here's the sample data from the three tables:
And here is the data model:
What I'm hoping to achieve is that, when I single-select slice to a specific category, the matrix will show the total $ that was paid based on each account's Start/End Date range. So, based on the data, New Accounts that had a StartDate in June would show $3000 for New Accounts.
When sliced to Returning Accounts, it would show June with $600 (All Payments for Account #1 >= StartDate 6/21) and August with -$1500.
Does anyone have a brilliant idea or suggestion?
Hi @arpost ,
Measure:
Measure =
VAR _s =
SUMMARIZE (
'DateSummary',
[AcountKey],
[StartDate],
[EndDate],
"amount",
SUM ( OrderSummary[Amount] ),
FILTER (
OrderSummary,
[AccountKey] = DateSummary[AcountKey]
&& [TransactionDate] >= [StartDate]
&& IF ( ISBLANK ( [EndDate] ), TRUE (), [TransactionDate] <= [EndDate] )
SUMX (
_s,
[amount]
Pbix in the end you can refer.
Community Support Team _ chenwu zhu
Hi @arpost ,
Measure:
Measure =
VAR _s =
SUMMARIZE (
'DateSummary',
[AcountKey],
[StartDate],
[EndDate],
"amount",
FILTER (
OrderSummary,
SUMX (
_s,
[amount]
| 9 | |
| 5 | |
| 3 | |
| 3 |
| 13 | |
| 9 | |
| 8 | |
| 8 | |
| 7 |
