Hi all,
This is my first post on here so if I am not posting in the right spot splease direct me. I am use to writing SQL queries but my current job does not have a data base structure so I have been working in Power BI alot. I am trying to figure out how to make a case statement such as
"CASE
WHEN StartDate between '7/1/18' and '9/21/18' THEN 'FY19-Q1'
WHEN StartDate between '9/24/18' and '12/21/18' THEN 'FY19-Q2'
WHEN StartDate between '12/31/18' and '3/22/19' THEN 'FY19-Q3'
ELSE 'Find QTR'
END;"
-I have tried things similar to
"Test QTR =
Switch ( True()
'Tablename'[Start date] >=7/1/18, "FY19-Q1",
'Tablename'[Start date] >=9/24/18,"FY19-Q2"
But for some reason it is saying it is saying my start date column does not exist and I get the nice red squiggly. Would really appreciate some help!
Hi. I don't think you can use between in switch. It only asks for one value. You should get if from if from if. Like this:
IF(
AND( Table[StartDate] > DATE(1,7,2018) , Table[StartDate] < DATE(21,9,2018) ),
"FY19-Q1",
IF(
AND( Table[StartDate] > DATE(24,9,2018) , Table[StartDate] < DATE(21,12,2018) ),
"FY19-Q2",
IF(
AND( Table[StartDate] > DATE(31,12,2018) , Table[StartDate] < DATE(22,3,2018) ),
"FY19-Q3",
"Find QTR"
You should also try creating a Calendar Fiscal Date Table. It's like a regular calendar table but with the months and quarters of your business configured.
Hope this helps,
Happy to help!
| 19 | |
| 11 | |
| 9 | |
| 4 |
| 35 | |
| 32 | |
| 20 | |
| 12 | |
| 10 |
